Cadillac Forums
Cadillac Forums - Photo Galleries - Create an Account
Go Back   Cadillac Forum - Enthusiast forums for Cadillac Owners > Cadillac Models > Cadillac Seville
Old 10-17-2009, 03:01 PM
txcaddyman txcaddyman is offline
Default electrical problems on my 99 SLS
when i start my car the battery is a 13.9 or around there. when i put it in drive and start to drive it jumps to 16.1 or 16.9 and then i get messages saying "battery not charging" or "service charging systems". then my radio changes like i turned off the bass and my a/c goes from blowing cold air to reg air. has anybody had issues like this before? i cleared all the codes and removed the battery for a few moments but that did not work. please, any help.
Sponsored Links
Old 10-18-2009, 10:25 AM
92_Daddylac's Avatar
92_Daddylac 92_Daddylac is offline
have the alternator tested and see if it its overcharging. sometimes when alternators go bad they wont charge and some will over charge. i had a car that caused my battery to leak due to it overcharging at 18 volts. So see if you can get the charging system tested and let us know what you come up with.
__________________
Daddylac
http://www.cardomain.com/ride/3193930
Old 10-18-2009, 10:58 AM
slowroll slowroll is offline
Alternator is controlled by PCM also. Check connections, and ground wires are clean and tight. Post codes that come back.
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
