Cadillac Forums
Cadillac Forums - Photo Galleries - Create an Account
Go Back   Cadillac Forum - Enthusiast forums for Cadillac Owners > Cadillac Models > Cadillac Seville
Old 09-25-2009, 03:09 PM
Big Jake Big Jake is offline
Default Starting
My 1997 SLS has 108,000 miles on it and is hard to start after setting overnight. I have to try it 3 or 4 times before it will start. Once started it will start all day just fine.
Any suggestions? I haven't tried anything yet.
Thanks
Big Jake
Sponsored Links
Old 09-26-2009, 10:26 AM
slowroll slowroll is offline
Fuel pressure regulator - check for fuel leaking at vacuum port.
Old 09-26-2009, 09:40 PM
92_Daddylac's Avatar
92_Daddylac 92_Daddylac is offline
also try to change out the fuel filter if it hasnt been changedthey're cheap too. some times if a dirty fuel filter sets overnite the debris in the fuel filter clogs it up and then it makes it harder to start and once you try it a few times it not necessarily unclogs it but pushes some of the debris through. after you change it check pressure if it increased from before.
__________________
Daddylac
http://www.cardomain.com/ride/3193930
Old 10-09-2009, 08:37 PM
Thanks to Slowroll and 92 Daddylac.
I finally went to a friend, who is a mechanic, and he found out it was the fuel pump.
Since the fuel pump is in the fuel tank is was not an easy fix.
Big Jake
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
