Cadillac Forums
Cadillac Forums - Photo Galleries - Create an Account
Go Back   Cadillac Forum - Enthusiast forums for Cadillac Owners > Cadillac Models > Cadillac STS
Old 07-19-2009, 08:14 PM
mpayton mpayton is offline
Default cadillac overheating
i own a 97 sts with northstar. approx 1 year ago the radiator was replaced. approx 1 month ago the heater core burst and i bypassed it with a galvinized pipe in a u shape in the engine compartment. ever since then the car would overheat when driven approx 15 miles.
I finally replaced the heater core today, and poured 2 gallons of antifreeze into the system as it had all came out with the recent overheating events. the car today actually got hotter than it ever has been after the installation of the heater core. i dont know what is going on.
i dont know how to check the thermostat without taking it out, or to check the water pump. is there anyway to check these two things?
or is it possibly some thing else i havent thought of.
I NEED HELP BADLY. I am mechanically inclined and have no problems getting greasy i just need some direction.
thanks for reading my sob story.
Sponsored Links
Old 07-19-2009, 09:42 PM
luinet luinet is offline
I think the only safe way to check the thermostat is taking it out. My guess would be that it got stuck when you ran the car with low coolant and hot.
Old 07-20-2009, 03:04 AM
stomper stomper is offline
to check the stat, take it out, place it in a pot of water and a thermometer. heat the water watching to see when it opens.
Whether it tests good or bad, replace it with a new one.
you can see if the stat works by watching the coolant temp in the radiator, or by disconnecting the upper hrad hose .. but .. you gotta know what you are doing to not get mislead or worse, burned.
the test is only to tell you IF that was the problem or you got other issues. I expect the stat to test OK. will see.
report back ?
we will need more details to guide you then. read the help thread in the general tech section.
Quote:
Originally Posted by mpayton View Post
i own a 97 sts with northstar. approx 1 year ago the radiator was replaced. approx 1 month ago the heater core burst and i bypassed it with a galvanized pipe in a u shape in the engine compartment. ever since then the car would overheat when driven approx 15 miles.
I finally replaced the heater core today, and poured 2 gallons of antifreeze into the system asit had all came out with the recent overheating events. the car today actually got hotter than it ever has been after the installation of the heater core. i dont know what is going on.
__________________
"If you're going through hell, keep going"
~ Winston Churchill
Old 07-21-2009, 07:52 PM
the stat tested ok, but i replaced it anywys. the car still overheats what can i check next to find the problem
Old 07-21-2009, 08:08 PM
report back ?
Please read it ...
TECHs are here to HELP !
__________________
~ Winston Churchill
Old 11-02-2009, 07:10 PM
hollyberry hollyberry is offline
sounds like headgasket problems to me when you take heads off to replace gasket inserts need to be installed have heads checked for warpping when you have them off good luck
Old 11-04-2009, 09:40 PM
Mrmojorisin's Avatar
Mrmojorisin Mrmojorisin is offline
Was the bypass removed once the heater core was "finally" repaired properly....LMAO...?
Tags
01, 1993, bad, bypassed, cadilac, cadillac, core, heater, heating, message, overheated, overheating, problems, srx, sts, thermostat, transmission
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
