Cadillac Forums
Cadillac Forums - Photo Galleries - Create an Account
Go Back   Cadillac Forum - Enthusiast forums for Cadillac Owners > Cadillac Models > Cadillac Deville
  #21
Old 11-04-2009, 11:28 PM
slowroll slowroll is offline
Dealer should be able to pull up picture so you can point out what you need. Your question is some what confusing, are looking for a bolt that holds head to block or exhaust manifold to head?
Sponsored Links
  #22
Old 11-06-2009, 12:06 PM
detra319 detra319 is offline
Its a 4.5 v8, 90 cadillac deville. First off, I pulled the head, so I think I should replace 10 bolts. 5 inside the head itself, and 5 that are on the outside that go through the exhaust manifold and the head, iirc. Then on the exhaust manifold, there are bolts that hold the exhaust manifold to the head itself. I broke two of the bolts that hold the exhaust manifold to the head, and 2 of the bolts that go through the exhaust manifold AND the head were already broken, which was what was causing the head gasket to leak in the first place.
Tags
1990, allante, cadillac, cyl, cylinder, deville, gmc, high, idle, misfire, misfiring, miss, n5, problems, rough, suburban
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
