Cadillac Forums
Cadillac Forums - Photo Galleries - Create an Account
Go Back   Cadillac Forum - Enthusiast forums for Cadillac Owners > Cadillac Models > Cadillac STS
Old 12-22-2007, 12:30 PM
dpv1977 dpv1977 is offline
Default Emergency Brake??
I have a 2000 STS that failed inspection because the emergency brake would not work. I haven't been able to find any info about it. The manual refers only to a parking brake that you push the same time as the brake pedal and that is working fine, it releases properly when shifting to drive. When in gear the "emergency brake" pedal does nothing. Any help or guidance would be greatly appreciated....thankyou
__________________
David
2000 STS
Sponsored Links
Old 12-22-2007, 11:32 PM
slowroll slowroll is offline
Default RE: Emergency Brake??
Parking brake should hold with foot holding park brake pedal down in gear at idle. With rear tires off the ground. Appy parking brake see if either wheel will hold. If neither one hold check brake cable adjustment and operation of actuators on rear calipers. If one holds and not the other it may be caliper. If cable will fully actuate lever on rear caliper and pads wont hold rotor, you will need to replace rear calipers. It is recommend to replace hydralic brake componets in pairs...right and left.
Old 12-25-2007, 09:22 PM
I will do all you've suggested, thankyou again slowroll
__________________
David
2000 STS
Old 10-06-2009, 01:43 PM
mazzman mazzman is offline
Default How do you change emergancy brake foot pedal assembly on 98 Cadillac STS?
How do you change emergancy brake foot pedal assembly on 98 Cadillac STS? I have a new unit but need instructions (hopefully pictures) to remove and replace the unit under the dash.
Old 11-04-2009, 11:53 PM
stomper stomper is offline
Quote:
exactly why are you trying to change the foot pedal assy?
i hope is not due to failure to release which can be caused by a failed solenoid activated via the shifter.
__________________
"If you're going through hell, keep going"
~ Winston Churchill
Old 11-05-2009, 10:37 AM
Stomper,
In order to release the emergency brake, I have to go under the dash and push the lever. Is it only the selenoid?
MAZZMAN
Old 11-05-2009, 11:00 AM
Stomper,
In order to release the emergency brake, I have to go under the dash and push the lever. Is it only the solenoid?
MAZZMAN
yes !
that is the "manual" release for when the automatic system fails
also, some cars also have a vacuum system.
I dont know which system you got.
__________________
~ Winston Churchill
Old 11-07-2009, 12:14 AM
Mrmojorisin's Avatar
Mrmojorisin Mrmojorisin is offline
He has a 98 STS
Tags
2000seville, 98, adjust, adjustment, brake, cadillac, cts, deville, emeergency, emergecy, emergency, lever, manual, parking, release
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
