Cadillac Forums
Cadillac Forums - Photo Galleries - Create an Account
Go Back   Cadillac Forum - Enthusiast forums for Cadillac Owners > Cadillac Models > Cadillac PininFarina Allante
  #11
Old 02-19-2009, 02:15 AM
Stealth Stealth is offline
Send a message via Yahoo to Stealth
cleaning up the alphabet soup above (site's upgrade?)
excellent point ...
STA-BIL, Americas top selling fuel stabilizer, is a blend of scientific additives that prevents fuel from deteriorating so engines start quickly and easily after storage. should be used in any vehicle or power equipment that is used requently or stored for more than 60 days. Also, treat fuel in gas cans or storage tanks as soon as purchased so fuel will stay fresh. STA-BIL Fuel Stabilizer ensures quick, easy starts in all 2 & 4 cycle engines. It is safe to use in all cars, trucks, SUVs, boat motors, marine engines, tractors, motorhomes, motorcycles, ATVs,snowmobiles, jet skis, lawnmowers, snow blowers, tillers, weed trimmers, golf carts, power washers and generators. Use in gas, gas/oil mixtures, oxygenated fuel, reformulated gas, and dieselfuel.
One ounce of STA-BIL Fuel Stabilizer will keep 2-1/2 gallons of fuel fresh for 12 months. Using twice the recommended dosage will keep fuel fresh for up to 24 months.
Twenty-Five PLUS important items/maintenance to do on 87 to 92 models:
1. Get a FACTORY SERVICE MANUAL.
2. Get a Owners MANUAL.
3. Check torque of wheel lug-nuts, several incidents reported.
4. Check performance of ABS ac***ulator and ABS pump.
5. flush brake fluid from pump and master cylinder.
6. Replace brake hoses at wheels and ABS relay at 75,000 miles.
7. Drain coolant (do NOT flush) and refill with 50/50 mix. Engine seals tend to fail.
8. flush HEATER and its hoses.
9. Replace hoses, serpentine belt. Carry a spare belt.
10. Replace wipers. Carry a spare set, hard to find.
11. Drain transmission fluid (do NOT flush), refill and replace filter.
12. Remove soft top helper springs. They break the boot well.
13. Carry a jumper for the VATS ignition on a 89 and newer. When it fails, you are stuck.
14. Modify the top pull down motor assy. Carry instructions of how to repair.
15. Install a boot-cover restraint system to avoid accidental opening.
16. Lotion seats (use formula with: lanolin, mink oil & neatsfoot oil). Repair as needed.
17. Replace spark plugs with platinum plugs. Also replace primary wires.
18. Find & test manual releases: parking brake, fuel door, trunk release, trunk partition.
19. Clean all electrical contacts you can pull and apply die-electric-lub.
20. Clean the door latches.
21. Lubricate the soft top weatherstrip with Dupont Krytox®. It is EXPENSIVE to replace.
22. Repair frayed edges, cables, rips, holes on soft top. Waterproof canvas.
23. Check the spare tire. Often it is flat.
24. Inspect tail light bulbs, assure they are well mounted in the sockets. Arrays tend to melt.
25. Lubricate all latches/hinges in hood, trunk, also lub antenna mast, door hinges, etc. (do NOT lub door latches which must be free of oil).
26 - Add a 14oz bottle of LUCAS Transmission fluid.
27 - Wax the tail lights and headlights.
28. Buy a Diagnostic System Pocket Manual (codes book).
29. Make sure that you dont store car with a full tank full of fuel (with E85 ethanol) that turns to GELATIN or varnish.
__________________
Home of the Allante XYZ Facts & Allante FAQ
~ Stealth
Sponsored Links
  #12
Old 04-23-2009, 09:43 AM
Wipers123 Wipers123 is offline
I love this list!! Thank you!!
Jeff
Tags
1993, 88, 92, allante, cadillac, changing, eldorado, flushing, forum, hood, lamp, maintenance, plugs, radiator, spark, voltage
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
